100HP DAP Injectors with aftermarket Bodies for 98-02 match flowed VOC
- Replies 44
- Views 8.5k
Scottyv 13 posts
Evan 11 posts
dripley 9 posts
Mopar1973Man 6 posts
I have been told the opposite - that the six speed transmissions are stronger. I have a NV5600 with 320,000 miles on it and it has been trouble free and still operates like it is new. I tow frequent
without someway to boost fool there isn't much to be done to increase power. I would skip the HR pump, sell it and buy a tuner.
You need a boost fooler and a boost elbow. Without that the ecm will defuel and the wastegate will open. You wont notice much difference in power without doing the above.
100HP DAP Injectors with aftermarket Bodies for 98-02 match flowed VOC?
I Have a set of these and My Stockers have 147 on them, thinking of swapping these in, when I do the Valve lap tune up.
I also have a HP VP44 , and was wondering if I should give it a try against my stock VP44, (was wondering if that would bode well with the 100HP injectors.)
I thought maybe this would keep me from needing a tuner.
My Turbo is the HX35
Let me know what you guys think
