Vp44 rear bracket bolt broke in block
- Replies 13
- Views 4.8k
Liviniuk 4 posts
Mopar1973Man 2 posts
dripley 2 posts
JAG1 2 posts
Popular Days
I managed to move the vp/sp just enough to get to the broken bolts. Nice and gently with a 1/8th bit I made a hole and used an easy out and got the top stud out...then the bottom bolt had a bit of thr
Sometimes ignorance is bliss. Then other times it grabs by balls.
If the broken bolt is crossed, seized, completely un-removable it may be easier to fab up a new rear mount that uses a different bolt on the block. Better than nothing.
So...need honest answers. What's the worst case scenario if a rear mounting bracket isn't used for the vp44. I've heard of guys who had 200plus or more not notice until the vp44 change. I honestly dont feel like pulling the steering pump and try to easy out a broken bolt out of the block. Had anyone heard of anything go catastrophically wrong if there is no rear mount?
