New Quadzilla installed--low power and 0 smoke?
- Replies 54
- Views 12.3k
Mopar1973Man 12 posts
dripley 10 posts
Otto8335 9 posts
gimmie11s 7 posts
I guess im probably more excited about some of that cummins l6 exhaust sound. My truck has 4.10's so it should run a bit cooler towing hopefully. Couple pics of my girl..loving this t
look at our hosted tunes, the default tune is VERY safe for ANY application and isn't really geared towards being super aggressiv both of these tunes will give a much different feel than t
Did you build a fuel map? If the fuel map is all 100% then it will do nothing but be stock. Yes if you not build a custom tune and relying on the factory setup. I'm wonder if you
Hi Guys.. truck is a 1999 nv4500 4x4 3/4 ton. Virgin i just bought off original owner with 169k miles. Stock injectors. Only mods are gauges and a FASS pump.
Added Quad ADR today with iquad for android. I HAVE NOT TAPPED THE PUMP YET and had planned to run on lvl 3 for now...
Got correct truck profile selected and quad app is reading all engine parameters.. went for test drive..... Valet mode (lvl 1) works.. half power limp mode lol.
Turned it up to lvl 3 which should be timing and max Can bus fueling and truck is weak. I am actually having a hard time telling if it is more powerful than level 0 (stock) ?? Definitely does not feel like a 65hp increase.
No smoke, and weak power delivery. Can hardly get EGTs to 850* on a WOT run.
Is this normal? I figured i'd at least get some smoke with max can bus fuel... no? Or is wire tap going to be required?
Supporting mods;
Glow Shift Boost/fuel psi/pyro gauges
FASS pump
New stock clutch
Edited by gimmie11s
