ABS light removal definitvely
Hi, Excuse me to disturb you, I have a dodge ram 98.5 cummins 24v with 4wd, and I would like to remove definityvely the light on instrument panel ( not the bulb) , but I would like to remove all abs wire which go to the dash board and cause the lights on . I have changed all wheels speed sensors, and I think its now the abs module. SO  As I have no money to change it I would like to remove. I imagine there is a wire behind the instrument cluster which arrive to signal a problem with abs , so I would like to cut it to finish with this. Thank you for your help.
Edited by Jeremy9806
  • Replies 16
  • Views 3.9k
Jeremy,
I don't think this is possible.  The reason being, the ABS signals are not hard wired into the cluster.  They are triggered through the CCD system(the communication languages between the different computer modules.)
This is from a 2001 Factory Service Manual, but I expect yours to be exactly the same or similar.
(EMIC is the ElectroMechanical Instrument Cluster)
GL  HTH
Hag
Ok, So there is only an other solution, to remove the bulb and paint it black
thank you for your help.
or there is another solution , I have dodge ram 2001 book with all diagrams, there are so many things its not easy to understand all, so  I think, there is a signal out to the abs module to the pcm, If I know the voltage or the ohms of this signal I can bypass it with other electronic components  and the signal out will go to the PCM without changing, and the light never comes because the PCM think the abs module works perfectly!
SO I need to know which wire go from ABS module to PCM and know  the signal if it's voltage current or ohm which is sent to the pcm
Excuse me but with all these diagrams and connector I dont see where is the abs bulb wire, so I understand the message go to ccd bus, but there is something to illuminate this light. I think its not easy, but not impossible. Or the last solution to paint my bulb in black
so Thank you if you have an idea I take. I hate electronic, the constructor cars made all these electronics like that there are nobody can touch it, all your change all or you can't drive. Im starting to regret the old cars , with no electronics !!!
I think you're trying to say you would rather have an older car without all electronics.
ABS module can't be removed...
Speedometer won't work.
Grid heaters won't shut off after 20 MPH.
Cruise control will fail.
Maybe a few other issues.
send the module to get repaired, module master or there are others
Ok so thank you very much everybody for your help.
I think I m going to send my module to module master.
Thank you
Yes I ve seen. Iunplug it and  I had no speedometer. I think all the wires are multiplex it s a problem, so I will send my module to module master. Thank you you very much for your great help.
4 hours ago, joeld79 said:
http://siaelec.com/product-category/brake-control-module/
was like $60 when I had mine serviced a year ago
Wow that's a lot cheaper then module masters, but I wonder on work quality if all wear parts get replaced or just what failed. I went with ModuleMaster because of good reviews and how long they been in business and @Mopar1973Man  delt with them back in the day and his module still works.
I find it hard to believe they do all that work for $50, just to open the stupid module take some time and patience. I done talking for now as I never had experience with cia.
its just a simple micro solder procedure, mine works fine still no need to get worked up about it lol
Yeah I jumped into Module Master back in the day and for $130 and being able to visit the shop and meet the people which was awesome. Took care of me very well. I'd would still use Module masters again.
For a company to do a repair for $50 makes me nervous. Not to mention the Module master 5 year warranty that is worth it.. SIA is only one year warranty.
well the one advantage to living in idaho lol
Not really being it was over 4 hours to get to there shop and then 4 hours to get home. From that point I had them mail the module back to me.
Ok, I found a little solution for abs light! I remove the dash glass and I put black scotch behind the gauges. And it works waiting I send the abs module to repair
When my 01 ABS light went off, turned out it was the connection right above the rear diff.  To this day I got a hose clamp screwed around the connection.
To trouble shoot,  I disconnected the connection and put in little jumper wires.
  I don't know if 98 1/2 and 01 is a same wiring.
