- Replies 16
- Views 3.5k
joeld79 4 posts
Jeremy9806 4 posts
Mopar1973Man 3 posts
Dieselfuture 3 posts
send the module to get repaired, module master or there are others
Yes
Just had mine fixed at ModuleMaster great service and people
Hi, Excuse me to disturb you, I have a dodge ram 98.5 cummins 24v with 4wd, and I would like to remove definityvely the light on instrument panel ( not the bulb) , but I would like to remove all abs wire which go to the dash board and cause the lights on . I have changed all wheels speed sensors, and I think its now the abs module. SO As I have no money to change it I would like to remove. I imagine there is a wire behind the instrument cluster which arrive to signal a problem with abs , so I would like to cut it to finish with this. Thank you for your help.
Edited by Jeremy9806
