- Replies 108
- Views 26.2k
Gregturley 40 posts
Mopar1973Man 19 posts
dripley 13 posts
kzimmer 13 posts
For those that don't care for the Bluetooth module being under the hood this was my fix. Made an extension cable with a connector from EBay and some flat 4 trailer wiring. Now its inside going to be s
The toughest thing to handle is the timing. That depends partial on weather and fuel type (winterized or summer). Quadzilla was design more so with performance in mind but with some careful thought an
Got the Quad and a Stealth Cover on the way. Should be here Wed. Time to sell the XZT.
Had some good luck in the last 3 weeks and I suddenly have money for a Quad and I have a few questions.
I have a fuel pressure gauge in the truck already so is there any real reason to get the fuel pressure sender for the Quad?
I have RV275 injectors and a stock HY35 with a spring on the waste gate and make about 28 psi max.
Trans has a stock rebuild on it done about 25,000 miles ago.
I'm not looking to make 500 hp or anything I just want 275-300 hp.
The most important thing right now is fuel mileage. I'm getting 12.5-12.75 right now.
Is there a tune on here that anyone would recommend for my combo?
Is there anything I need to do before installing the Quad?
Can I just put the Quad in without hooking it up to a computer or does that have to be done before use?
I do not plan on the wire tap at this time. If i do it in the future i will use a Stealth Plate.
Thanks for any help and please feel free to give me any advice that may be helpful in getting this thing up and running.
Edited by Gregturley
