- Replies 7
- Views 2.2k
Haggar 2 posts
Mopar1973Man 1 post
UnrulyDually 1 post
Bullet 1 post
Popular Days
I'm not sure that is a good idea with no driveshaft and a rear slip yoke cuz you will most likely be losing fluid out of the back of the t-case. Every time I pull the rear driveshaft I alw
Yep the only problem is the leaking fluid. I found a cap for a fabric softener or something and slipped right in and contacted the the TC output seal. Held it in with duct tape and wire t
I lost the rear driveshaft on my truck. Just wondering how bad it is to drive in 4x4 with no rear shaft?!
