No driveshaft
I lost the rear driveshaft on my truck. Just wondering how bad it is to drive in 4x4 with no rear shaft?!
  • Replies 7
  • Views 2.2k
  • I'm not sure that is a good idea with no driveshaft and a rear slip yoke cuz you will most likely be losing fluid out of the back of the t-case.   Every time I pull the rear driveshaft I alw
  • Yep the only problem is the leaking fluid.   I found a cap for a fabric softener or something and slipped right in and contacted the the TC output seal.  Held it in with duct tape and wire t
Itl be fine. Might grab alittle turning.
I'd run on freeway and feel good about it.
Every time I pull the rear driveshaft I always get some fluid dripping.  I would imagine that more would come out if it were constantly spinning.  I could be wrong but I wouldn't do it.
If you had a fixed flange mount on the t-case with a slip driveshaft I could see how that wouldn't be a problem running it that way.
I found a cap for a fabric softener or something and slipped right in and contacted the the TC output seal.  Held it in with duct tape and wire ties for a week while troubleshooting some vibration issues.
HTH
Hag
Not something I would suggest. The fluid leaking from the transfer case would be a problem.
Ok thnx guys. Didn’t have to take it far so I don’t think there should b too much fluid gone
HTH
Hag
Did you find the vibration issue?? Im having vibration issues too an have blown out 2 steady bearings in lke a month!?
wow!  2 intermediates?  no fun!!
Make sure your slip yoke moves SUPER freely.
Ours turned out to be bent rims.... like 4 of the 6....  it was pretty amazing.  (explained why swapping wheels around didn't seem to move the issue.)  It really wasn't a bad shake.  I would have lived with it, but it was buddies truck and it bothered him to the nth degree.  lol.
Good Luck finding it!
Hag
I sold a 1980 Ramcharger that way.  I left the parking brake on and twisted the driveshaft in half while trying to move it around the yard.  It had a fixed rear yoke though so the guy drove it home in front wheel drive.
