Fried ECM from lift pump wiring? Also ECM pin 44?
- Replies 45
- Views 24.1k
the7t7 19 posts
JAG1 10 posts
dripley 5 posts
Dieselfuture 4 posts
You're doing a good job cleaning up the electrical on the truck. Are you still waiting to hear from the ECM repair people about which part failed and what system it controls? Can you trace the c
I would wait for the results and in the mean time do other repairs.
That wouldn't do it. The power to the fuel pump would be battery/PDC fuse, to relay terminal 30, to relay terminal 87, to fuel pump. In a proper installation the fuse would blow. The ECM powers rel
I recently fried my second ECM. It died in the same way as the last one. Stumbled will cruising around town and then died completely. It felt like the lift pump failed but the VP44 kept trying for a bit and then it stopped too. After getting it towed home I could get both the Fass lift pump and the injection pump to run (and the truck to idle) by bypassing the ecm but got no voltage signals from ecm to either lift pump or injection pump when trying to start the truck with e dry thing wired normally.
After reading the article here by IBM mobile about proper lift pump wiring, I believe the ecm failed because the relay that was used in the lift pump wiring didn’t have a diode which allowed the relay coil to back feed to the ecm and fry the lift pump circuit in the ecm. I believe I’m in the same boat as another thread’s poster as my instructions from Fass had me using the ecm lift pump feed as the trigger for the relay, but now Fass recommends using an ignition switched trigger instead. I will probably not use the ecm to trigger the lift pump with the next ecm (even with a diode relay) as I just don’t want to take the chance.
I want to really be as sure as can that this is really the cause because if I fry another ecm, I’ll probably drive the truck off a cliff. I have done the W-T mod and am in the process of upgrading all my battery cables and grounds, though they weren’t in that bad of shape. I have ohm tested the ecm’s power leads and grounds as well as the injectin pump’s ecm power and ground wires. All wire runs read less than 0.5 ohms. Anyone have any more suggestions to check?
Also, while testing the vp44 connector’s wires back to the ecm and pdc, I noticed that my truck is missing one vp44 connector pin that goes to ecm pin 44. I am using the wiring diagram from here that is I believe either for a 1999 or 2000. My truck is a 1998. A pin out that I have describes the pin as “datalink shield injector pump”. Anyone know what this wire/pin is for? It doesn’t look like my truck ever had this pin as there are no extra wires in the harness. Thanks for any help anyone can give me.
Edited by the7t7
