Door misalignment, how to fix this?
- Replies 10
- Views 2.7k
Doubletrouble 3 posts
98whitelightnin 2 posts
JAG1 2 posts
IBMobile 1 post
Popular Days
IBMobile had the top of his door pulled out so hard I believe it broke the glass. A bear did that trying to get to the candy he won't stop leavin in there. He has no teeth left, but won't stop eatin i
'My door looks the same as @Doubletrouble"s and yes, a bear did it. The bears put there claws between the top of the door and the body and pull bending the window frame until the glass brakes. The b
I know you can adjust door hinges and such but I don't believe this is the case here. I have pics from down the side of the body bottom, middle and top of the door to show what I mean. Not sure how to go about adjusting this. Roll window down, put a wood block in the door and push on the top portion only?
