P1689, VP, ECM, TIPM, AND DASH...UGGGHHH
- Replies 19
- Views 4.2k
Cjugg 8 posts
dripley 5 posts
Dieselfuture 3 posts
Mopar1973Man 1 post
Typically guys that are rolling coal are considered poor tuners. Smoke is NOT a sign of good power. Smoke is a sign of improper timing and excessive fuel mapping for said amount of boost.
Could be vp related, multiple reports before they go they can smoke like that. Did you happen to smell it? Is this your actual mileage or some random number that got displayed
We might help if you promise to cut down on that, I know it's fun and all but gives us all a bad name in the eye of general public.
So I'm gonna be as thorough as I can, but sorry if I'm vauge..
Truck ran fine, had the Smarty on it, rolling coal...did some brakes and ball joints, let the truck down off the jack, cranked it and started white/blue smoking...dont really recall was kinda worried, shut it down, limped him home and parked.
Later got it cranked, parked for months, drove it about 45 miles, lost compression in 3rd, downshifted and caught boost, got it where I was going, parked it again...didnt have the money to fool around with it...
8 months later....got batteries charged, oil filter, fuel filter, and air filter
Was running and smoking...dash and all on, odometer reading 512000 miles..
Got it where it currently is, to work on it, did research, checked my oil...wth!? Milky..wasn't that way before I moved or anything..
Changed with some used oil and new filter..
Same thing, took filter housing off, found ripped water jacket...Indian head shellac, and then thought, why not revamp the oil, and timing cover? So I did, upon pulling head, found a seap in my headgasket, I did not go back and retorque after the studs went in...so entirely new job, kinda..
Copper coated headgasket, and ran permatex on block, re torqued. Upon putting all parts on, after I had some fun painting but still needs ALOT of work on that...I found my batteries to be dead, nothing on dash, no turn over, nada..
New batteries, truck turns over, only light I get is WTS, if you see my profile pic of dash, you see the Odometer reads ' 0', which told me the ECM, or smarty erased, or faulted my computer, revert back to stock, still no dash lights, no crank. Cant read odometer, cant pull codes through there. Smarty read me a few, which have since gone away, but they were P1689, P1693, P1697 and one other I cant recall...did WT ground mod. And re routed charging wire to aux batt, with protection 150a breaker...
Got some dash, like blinker, but nothing on initial turn ket. Just TWS, and brake if I have set..
The VP communication to ECM, was one that worried me...but that code went away after WT mod, companion to jtech mod, and no bus, I tried a diff pcm, and got all same code..I have not clue what to do, beside a harness and an ECM. Also when swapping fuel relay, with key on, it shocked the crap outta my buddy and when I swapped it, it made multiple clicking noises....no matter what relay I used, please lmk if anyone has had this issues with Odom not lighting, and when my buddy used his handheld reader ot only pulls up 1689 code, twice..
Iv loaded the pic my dash, with "0" miles, but as you see the low fuel symbal? That's not on now, and fuel gauge has been broke since I bought the truck, as well as the pic reading proper temps, it will not read them now..and my odometer is completely blank..
