Do Dying VP44s Always Throw Codes?
- Replies 13
- Views 3.6k
Octafish 6 posts
dave110 2 posts
Haggar 2 posts
Great work! 1 post
My brother's VP never fully died, but never ever threw a code. For years it would have fits of dead pedal. Real randomly and intermittently. Eventually it would have dead pedal until it warmed up.
I had hard starting issues about 6 weeks before mine failed. Got 216 code when the idle started messing up. Cleared it and came back 3 days later when the pump failed completely. Checking out Blue Chi
That's what I'd do. Sure sounds like an air leak to me. I'd suspect the manual LP or the draw staw. Tough to say which one. Clear hose trick would tell you if there's air in the lines.
I have a suspicion I may have VP problems.
But no codes with a good scanner.
I know these pumps can be tricky.
Truck starts immediately and quits after a second.
Try and start 2nd time - does the same thing.
3rd try, finally starts and stay started but runs rough for a 7 seconds then clears up, runs fine.
Drivability is normal .
Point nose down hill - no improvement.
I installed a Fuel Boss about 500mi ago and it has been great.
Cleaned pressure valve in pressure line (included w/Fuel Boss plumbing).
New crossover tube O-rings and injectors 1500mi ago.
New return T O-rings, new banjo washers.
Triple checked pressure and return line for leaks.
The only thing I haven't done is lift the bed, check draw straw V and connections at the tank.
I have several tunes downloaded for the Quad.
There are some that the Quad doesn't like (surging, VP gets noisy then quiet).
I thought that was kinda strange that the truck didn't like those.
However some tunes work fine.
Anyway, this is my dilemma.
Anyone have the same experiences?
