Nation 180A
Hey guys, quick question.
I ordered a Nations 180A alternator for my 02 cummins. Is it a drop in/plug and play? Does anything need to be changed with it?
I have the bosch 136A currently and am trying to reduce AC ripple.
  • Replies 30
  • Views 12.6k
  • The AC noise is for when the nations begins making AC noise.  It is an alternator and just like all alternators no matter who made them, It makes AC power.  Electronics inside the alternator clip the
  • As a member of the electrically challanged club, dont let opening the wiring loom bother you. There is not a lot of wires in that loom. The mod is pretty straight forward if you can look around all of
    Walmart battery work great I'm almost to 10 years on these batteries. Tidbit there is only 3 companies that manufacture batteries. Then on top of that Walmart batteries are the very same battery
So... the general consensus is I am good to got on installing the nations 180a this weekend without messing anything up,  and to further help with the ac ripple, do the w/t mod and pcm protection mod.
also what are yalls recommendations on batteries? I have optima red tops now and am not a big fan of them.
Actually it reduces the AC noise because its is NOT running beside the ground for the ECM and VP44. Then the grounds are over 4 feet shorter. The charge lead is now on the passenger side and the grounds go to the driver side. There is distance between the ground leads and the alternator charge lead now.
Stock setup you can see the ground and charge lead running parallel to each other.
After the mod... ECM and VP44 grounds are tied to the gear case.
Then the alternator charge line goes to the passenger battery but passing through a 150A circuit breaker.
Walmart batteries work fine if you maintain them
Tidbit there is only 3 companies that manufacture batteries. Then on top of that Walmart batteries are the very same battery the factory installed back in the day typically an upgrade to 810 CCA or so.
AGM batteries I'm no fond of at all seen several explode, can't add distill water. Then you can't equalize charge the batteries to clean the plates of sulphation. Being all the battery in my vehicles last over 10 years I'll stick with lead acid batteries. Even the batteries power my home are going to surpass 10 years soon. I've got a 1,000 pounds of lead acid batteries. (Solar and hydro powered home).
My thinking on the batteries acting as filters that helps remove AC ripple is something I read a few times on the internet, so is it not true then? :think:
8 hours ago, HOUTX02 said:
The 140a fuse wont be used because the breaker will replace it?
You can still use that terminal at PDC for other devices, just use another fuse appropriate size to device or 140 may not pop but you wires will melt. I'm using it for few things, like fuel pump and some other things I have on truck, combined fuses amp I'm around 40.
Don't mean to confuse you any further :rolleyes:
On 2/12/2020 at 2:48 PM, HOUTX02 said:
Ok thanks, Forgive my ignorance here.... I understand that the W-T ground mod is too help reduce AC ripple; And the PCM protection fuse is for proctecting the PCM incase of a rare short correct? So why are these required for the  Nations 180A? Not trying to argue, just trying to understand. Nations told me it was a drop in and plug and play...
It's not that rare. I fried my PCM on a botched rebuilt alternator.
Granted that simple missing ring cost me about $400 and lead to one of the most prolific articles ever written.
Was it rebuilt by your rebuilder or was it an auto parts store item? Are you saying it was a missing slip ring? Sorry I have big thick skull and need elaboration for it to get thru.
I rebuilt it myself. I was rebuilding alternators and testing out different diode packs and I left the sealing ring out. It's funny I always bench tested them before I put it in. Dum me. For not doing that time.
Lucky it was just on my truck, I rebuilt several and luckily for me it was the for my truck that was botched.
That is because of the alternator had a short on the blue wire field lead. This will be a dead short back to the PCM which supplies the +12V. The PCM is protected by a 20A fuse and the circuit board can't hold the current flow. POOF! Magic smoke released form the circuit board. This is where the protection fuse mod comes in. This protects the PCM from current over 5A and the fuse blows not the PCM.
Yeah I know you know that but the rest might not...
