DO EXHAUST RESONATORS ROB HORSEPOWER??
  • Replies 33
  • Views 9.2k
Back when all I was running was the EZ, I know for a fact that when I replaced my 3" straight piped factory exhaust with a 4" exhaust system I gained some HP.  I dont believe it was copious amounts because it was nothing the butt detector could register, but I'm going to guess around 10 HP.  Just enough to make the stock clutch slip at WOT while pulling my 5th wheel up a steep grade in 4th gear.  There was no denying the gain either since there was zero other variables to consider.  I literally did nothing else from one day making that pull to another day making the same exact pull but with a new exhaust system...
I would not doubt one bit you made power with a 4" exhaust.
I saw lower egts going from 4-5.
I saw squat going to the bd pulse 3 peice manifold.  Nothing on gauges or but dyno.
I've got a 5" FTE resonator and a muffler on my 4th gen.
Before adding the FTE, I just had the muffler. I didn't notice any difference when I added the resonator in (EGTs, mpg, or butt dyno). I'm guessing my hp is around 385-400. I doubt you'd notice anything.
That said - FTE is known to cause restriction.
Edited by TFaoro
On 2/13/2020 at 6:53 PM, KATOOM said:
I vote someone with an FTE do a with and without dyno test for us all...  For educational purposes of course.  :smart:
It makes a world of a difference in sound.
My exhaust finally broke before my FTE resonator the other day. As for me I didn't notice any performance difference. Now I suspect that is because the 4" is much larger then the flow of the motor.  Therefore any restriction that could be there is not there.
The only difference is sound, that drone is killer. Irony has it that I was looking to replace that exhaust because it was coming apart anyways. Now I have an excuse to replace it.
You guys are going to make me get a 5" x30" resonator and try it out. I can't hear myself think if I drive over 80
I'm debating  54" Donaldson.  I must b getting old
:shrug: 4" does not drone at all at 80 MPH. (not towing) but towing it can drone quite loud.
I don't advise thinking over 72.
I got a 4" downpipe that starts as a 3 at turbo then 5" all the way back with a muffler I think, I don't want to chocke it if I don't have to ( no funny chicken jokes here ). If fte offer a 5" I might try it out. I think my truck been getting louder lately or I'm getting old like @Evan how does Donaldson compare to fte? Does it have performance in it's mind at all or just aimed at reducing noise?
I usually don't but been driving so much lately, I just want to get where I'm going and don't really care about mpg and my brain, all though it be nice to get around 20 going 80 and not be brain dead by the time I get where I'm going, or I'll never know why I went there in the first place :think:
Don't worry. The older I get the more I realize insanity can be a pleasure :ahhh:
Oh, and FWIW I've heard good things about the Donaldson 51". Never tried on though.
Edited by dave110
Don't worry. The older I get the more I realize insanity can be pleasure expected:ahhh:
Fixed it for ya...
Edited by KATOOM
51" Donaldson fits semi's 5" exhaust straight through design.  Walker also makes one and napa sells they're brand.
Donaldson has cfm ratings and sound levels.  There is  straight throughand one with baffles
