- Replies 16
- Views 3.2k
dodgedieselnewbie 5 posts
Mopar1973Man 3 posts
kzimmer 3 posts
Dieselfuture 2 posts
I had 150k miles on my stock injectors. Had them tested 260 bar on average this is 30 bar below minimum. Then the engine load was zero and idled at 875 RPM. These where completely wasted and unusable
Twice.. added Lucas both times.
I got maybe 20K out of my DAP nozzles. Got 3 replaced under warranty and had them assemble them on a new second set of bodies... And they came set to 315-320 bar instead of the 335 that I requested. A
Hey all.. I installed a catch can on my truck a little over a week ago to avoid the oil spots on the driveway. Well.. after one week it collected around 9-10 ounces. Seems pretty excessive.. or no? If so.. why or what is causing it? Thank you....
