Heater Climate Control Unit fan switch failure?
- Replies 22
- Views 4.4k
leety 9 posts
kzimmer 4 posts
dripley 2 posts
pepsi71ocean 2 posts
Lmao
Blower motor resistor(s) need replacement. Also, if the blower motor is drawing enough current to cook the resistors, you likely need a new blower motor as well, or you'll be replacing resistors again
When you remove the blower motor you will see it on the left side or rear in the hvac box. Its pretty obvious once you are contorted under there. The part you linked looks right. I did not compare any
It seems as though my fan switch has become a happy face Sad face type of fan switch. It works on high only. I suspect the switch may have failed.
I do have AC I do not have heated mirrors. I believe the unit is P/N 55056702AD
If anyone has any other thoughts on why that would be awesome.
