Cruise Control Off switch on Clutch fail
- Replies 11
- Views 1.9k
dripley 3 posts
Royal Squire 3 posts
leety 2 posts
IBMobile 1 post
Popular Days
Its the switch that wont let you start your straight drive unless you push the clutch in. The 02 was the first and only truck l have ever had with one. It bothered me so I bypassed it. About a year la
I use brake pedal
It should turn off when you push the clutch in. Mine does but l never tried to figure out how it dos it. Mine does rev up a few hundred rpm before it disconnects. But normaly I hit the cacel button si
I'm trying to determine where the switch is on the clutch pedal to turn off the cruise control when it's depressed. I didn't see it in the parts diagrams. It's not working. I have to remember to turn it off to down shift while in cruise control :-(
Any help with this would be much appreciated.
