Need fuel system help!
- Replies 20
- Views 4.7k
Doubletrouble 9 posts
dripley 7 posts
015point9 1 post
Tractorman 1 post
Popular Days
If it was sucking some air, fixing it would make difference. I understand the head thing. I put a new clutch and brake foot pads in mine after quite a while of looking at a shiny steel plate for clutc
I set out to change the pre lift pump filter today. Ordered a wix part# 33270 from Amazon. When I went to change it I found a mess from whom ever installed the FASS ddrp. They cut the original hard plastic line and slipped a loose fitting rubber line over it and installed the included filter. It had to have been sucking air in.
Question is, could I just go get some of the correct size rubber line (for fuel of course) and go from the quick connect fitting on the ddrp to when the plastic line turns into the aluminum hard line and install my filter in this rubber line?
Truck is down now so I need to get it fixed.
See pics below.
Just dodged (pun intended) an expensive bullet. The hard line was cut to adapt a screen filter pre lift pump. The soft like used was the wrong size and had to have been sucking air in.
I cut the hard line back a bit more and used some biofuel approved line of the correct size and spliced in my new filter. The line I had fits right to the hard line and I also installed spring type hose clamps to ensure an air tight fit.
Crisis averted!
Checked fuel pressure after the install, at idle I'm at 16-17 psi. While revving the engine and holding it a 2000 rpm it holds steady at 12psi. I know that isn't the most accurate with no load on the engine but I will get gauges as soon as I can.
