Been chasing TC lockup issues for awhile
- Replies 38
- Views 6.6k
Recian426 15 posts
wil440 8 posts
dripley 5 posts
Mopar1973Man 3 posts
When the apps goes bad we recommend the Timbo. I keep one under my back seat for replacement when the stock one goes bad. You can find it in this sites store section.
When the alternator field shorts to ground on the blue field wire it will completely burn up the PCM. This will cost you about 750 dollars to replace. Not to mention it burns up the voltage regulator
Bicycles beat me of the line until I pick up a couple of gears. - John
Like the title says I've got a 99 2500 been chasing this issue pretty much since I got the truck almost 2 years ago. Long story here I've dug and dug into research on it. Looked at other forums, looked at other pages, seen what worked. I even fixed a few when I worked at dodge by relocating the ground across the radiator. That's what led me to this site when I found out about the alternator AC issue. It made perfect sense seeing as my ECM has a bad microprocessor also. I tried all those bogus tricks. Nothing can seem to fix my truck short of a $3000 manual swap. Only one that really helped was cleaning and replacing bolts on battery terminals for about a week then it came back. I recently changed the diodes having 0.016vAC. I did the wiring mod in the process. I noticed a huge improvement. I'd say 95%. I'm still getting it after I set the cruise it'll do it only once right after vacuum grabs throttle and usually if I accelerate moderately from say 45-55 or 55-65 it'll kick out a couple times. Light throttle won't do it. Feels like same amount of throttle amount every time. Monitoring on scan tool the TC solenoid output in the PCM is still dropping out so I know it's not TC or solenoid. Tps volts look normal on the graph also. I have no doubts the tps volts is filtered so I may not see any system noise but if it lost voltage I'd see it on the graph. I'm wondering if I have an actual APPS issue. If so are aftermarket ones any good? Their electronics are usually junk
