- Replies 11
- Views 2.8k
Doubletrouble 3 posts
Mopar1973Man 2 posts
Dieselfuture 2 posts
Injunmark 2 posts
Popular Days
I didn't realize this could cause so much havoc. I need to do this ground mod soon!
I used to work for what is probably the best known construction machinery manufacturers on the planet, I was in major repair straight off the backhoe production line, problem was the whole deal was ma
They consistently trade safety and/or reliability to save a few dollars in production. It's sad but they all do it to some degree. In our trucks we have (in my opinion from driving large semi t
Hi guys, my 2002 5.9 24 valve has some issues and I want to verify I am doing the correct things before proceeding. It runs poorly and surges, the temp gauge is going near full almost immediately, and the check engine light is on. There are several high voltage codes including (P0563 charging system, P1475 Aux 5 volt output, P1286 APPS supply voltage, P0113 Intake air temp sensor, P0118 ECT voltage, P0238 MAP sensor) all stating voltage too high. Now I also have the P0606 ECM/PCM Processor code. I did an alternator A/C noise test and it failed (otherwise the charging system seems normal). I am able to scan codes but can not communicate to get any data whatsoever. My plan is to replace the computer and replace the alternator. My questions are : does this seem to be the correct course of action and if so, which computer needs replacement, the one on the passenger side firewall, or the one mounted on the drivers side of the engine block. Thanks in advance for your help, much appreciated
