Bad alternator/Engine Stutter
- Replies 6
- Views 5.2k
Mopar1973Man 3 posts
JAG1 1 post
Doubletrouble 1 post
jtrakel 1 post
So I have finally got my truck up and running after an extensive amount of maintenance that needed to be completed as the previous owner neglected the heck out of this poor girl. While everything was being worked on I went ahead and did the full W-T wiring modification and the alternator PCM protection as well that @Mopar1973Man has been so awesome at spreading around to everyone. I did not check the AC volts prior to the maintenance and W-T mod.
I went ahead and took a video of my results while the truck was running, unless i'm doing something wrong or have the incorrect setting my alternator is beyond BAD reading in at 1.04 AC volts which hopefully is the smoking gun for many of my electrical issues with the truck. I will provide a list of everything done to the truck recently for essay. Should I just scrap this alternator right now and get a new one?
I see Nations is a well regarded brand or maybe the Mean Green alternator on @dieselautopower site and do I need to be concerned with anything else that may be toast because of these readings (ECU, PCM etc.). I've spared no expense and thrown the everything minus the kitchen sink at this truck and want it to finally be reliable.
The only code I have is the P1693 which I understand simply states the ECM or PCM whichever is not reporting has an issue however I literally cannot find any other codes currently using the OBDLink MX+ on my iPhone XR with the provided app from the Company "OBDLink". Am I doing something wrong with my reader to not see anything else except the P1693?
* I posted a video before with the truck at idle having major issues and will post again. It does it while driving as well and typically the issue presents itself once the truck has warmed up and been running for 20-30 minutes. I am not able to get into the throttle at all or push through the issue because the truck dies on me while driving, sometimes when it's warmed up it will "stutter" if I rev the motor. Fuel pressure since I just installed the gauge and LP is right around 18-20psi at idle (sensor roughly 2ft from VP44).
Work done in the last 2 weeks:
REMOVED: Legacy quadzilla XZT, BD TQloc, AND A BD APPS noise filter
REPLACED/INSTALLED:
- W-T mod (with 150 Amp inline fuse for the alt)
- Alt/PCM protection w/appropriate inline fuse
- New MAP sensor, oil pressure sensor, IAT sensor, and Oil pressure sensor
- Installed ISSpro fuel press, EGT, boost, and trans temp
- FASS 165GPH LP used @IBMobile method of wiring the relay and it's awesome! (deleted factory block LP and filter may install later)
- Crazy Carls BHAF
- Quad Adrenaline (havent installed until I figure out electrical issues)
- Timbo APPS
- Rebuilt Vacuum pump
- Replaced tappet oil gasket
- Replaced front timing cover
- Cam shaft front seal
- Coolant flush, thermometer and water pump
- Complete heater grid delete
Next up is replacing the oil pan gasket, it's still leaking and the previous owner said he just did it but I don't believe him. Hopefully this ends my oil leak issues
Edited by jtrakel
