- Replies 18
- Views 2.8k
dripley 5 posts
Alexio Auditore 4 posts
Bullet 4 posts
Dieselfuture 3 posts
Popular Days
"the fluidampr weighs a bit more than stock and is a bit bigger in size too." and what I understand the glacier fuel boss has a real hard time fitting in with the fluid dampener, if you h
I had a small vibration at idle and it stopped it. I was also in the front motoer to reseal the gear case cover and replacing a damaged bumper, Figured I would replace it while I was in there. It did
Mine was changed under warranty but l cant remeber whether the sticker was still intact afterwards. But it was there when l bought it.
hey guys. So I was scrolling through a Genos catalog and came across the dampner for our trucks. I got to thinking about what the signs of failure were, and did a little research. Looking at mine, I see the rubber has been squeezing its way forward and looks to be getting old, 260k miles, but when idling, it doesnt wobble off balance at all. By comparison, my dads 99 looks really good, almost newish. I don't know if it was replaced at some point, but he's had the truck since 02 I believe and hasn't replaced it himself.
As they fail, I've heard you get more vibration through out the motor, but sometimes its real gradual that you may not notice it over time. If the rubber is squeezing out, is that another good sign of needing replacement soon?
To be honest, I think this is sometimes an over looked part that should be inspected when you do the occasional rounds of inspection on your motors, i know I haven't checked it enough.
The first picture is mine, the other two are my dads. You can still read the numbers on his.
