Sound like a boost leak ?
- Replies 15
- Views 3.9k
Evan 6 posts
Mopar1973Man 5 posts
Royal Squire 1 post
Cronus577 1 post
To me it sounds like a hole in your wallet that is making that noise
Over 100k on the injectors. I’d check for a boost leak. Either way I’d say your sticks are worn out especially if they were set at stock bar. You’re gonna love this but I’d ditch the smarty and get a
I can give this much... I created a massive boost leak on my truck to test the boost leak theory. I removed one intake manifold bolt, and remove the wastegate hose from the turbo. Took it
Rpm is 2200-2500 shes been smoking more than normal. Smarty is on 9 3 3 3. Used to only haze over 1800 when really on it.
Sac 100s are probably tired over 100k.
Would they still smoke at higher rpm.
I haven't pressure checked anything
It makes nearly 40psi. Putting around rarely over 20. Egts never over 1200 around town egts are 400-600 cruising about 750ish.
For some reason I suspect a boost leak.
Just thinking out loud as I've been noticing a noticable amount of smoke that isnt normal .
With about 10k behind it I was pushing black like a freight train getting into traffic on the freeway rpm was around 2000. I actually chopped the throttle thinking something was wrong and merged onto the freeway.
Thanks for helping me think.
