- Replies 14
- Views 4.6k
Jasonsneedinhelp 7 posts
Mopar1973Man 3 posts
dripley 1 post
JAG1 1 post
I need help here. I have a 2001 with the 6 speed. The clutch went out a couple weeks ago so I decided to do some long overdue work on the truck while tackling the clutch job. I put a new south bend dd in and a new slave cylinder assembly. I also changed the drivers fender as well and pressure washed the entire engine and undercarriage. The truck ran perfect when I shut it off to do all the work. I have the air dog 2 with a 2 year old industrial injection vp44. I've always had 20 psi fuel pressure at idle with about 17 at WOT. When I got everything back together and started the truck, it idles perfect but it won't rev above 2000 rpm and started defueling causing a missing and backfire around 1600-1800. It pours black/blue smoke like it's tuned but it has no programmer. I also had a horrible sudden fuel leak from the connector tubes so I changed all the orings and fixed that problem but still there was no change to the engine sputter and defueling. I ran the codes and had these codes P0234 p0113 p1698 p0251 p1287 p0252. I can't help but think I'm missing a ground somewhere or have something wrong or wet but can't figure it out. I have a hard time believing that the IP just quit at the same time I did all of this work. Any help would be appreciated.
