Tires that don't help wander?
- Replies 27
- Views 9.2k
totally lost 11 posts
Mopar1973Man 5 posts
Sycostang67 2 posts
tony.canto 2 posts
If you have a lift kit (leveling kit) then you need to have the caster angles reset for your truck. Then you need to get the thrust angle corrected for the track bar if its not adjustable. Every truck
Well I nearly took your advice today. Had a near new set of 245/75r16 10ply in front of me with cash in my pocket! Then looked at the actual weight rating of them. 3000lbs each. Yea thats not going to
So what is out there you guys have found that are decent on gravel roads and in mud that don't make these truck wander so bad on pavement? I have used many tires but most rougher treads make these trucks wonder and squirl all over the road. Especially Fierce attitudes! They seem to make everything drive bad. I had a set of pro comp mud terrains years ago that drove great but they have long been discontinued for a newer version that wonder all over the road. Only other tire i have tried that drove good are the michelin MS which are a street tread. I want something that does a bit better off road then street tires. Surly there are other good tires out there?
The bad ones i can remember off the top my head are
General grabblers AT, HWY driving was actually good but gravel was terrible and it literally got stuck on wet grass.
BFG AT basically the same tire as above.
BFG mud terrain yeah not going down this path again
Fierce attitudes. These get around decent but one of the worst wondering tires on pavement.
The new pro comp mud terrains again wonder on the HWY.
Im not trying to fix a front end problem. Everything is already in good shape.
