Partial dead pedal???
- Replies 12
- Views 3.7k
Beepbeep24v 4 posts
Mopar1973Man 2 posts
dripley 2 posts
Haggar 1 post
Hey guys looking for some answers on my 99 24 valve 3500 auto. It has bhaf/industrial injection vp44/and fass 150 with big hose lines and in tank sump all installed at same time about two years ago. Fuel pressure gauge is installed about a foot from ip with shrader valve cracked idk if it’s to close and giving an erratic reading but it will idle steady at about 14 then jump up to 18 while driving then all the way down to 10 then back up so basically it fluctuates up and down while driving between 18-10. Another thing that’s going on. sometimes it has a long start when hot sometimes not. And every day when cruising above 65 it will stop accelerating and only give me 30% throttle. boost drops to 4% apps shows to be working right with throttle response when This happens engine or rpms don’t shut down I can still run 60-70 just with only limited throttle and fuel pressure will stay at about 12-14 when it happens. Until it feels like kicking back in boost will jump up and engine will take off depending on where my throttle pos at time.showing no codes from autozone scanner. Recently did apps reset and didn’t work then installed new apps still nothing did reset on new apps and nothing. disconnected Grid heaters still nothing. Did alternator wire re route and still no change. Crank pos sensor went out. Was giving me code/ no crank/long cranks. Replaced with Cummins sensor. Code went away and still having the issues. Checked grounds and terminals/pcm connections all seem ok so idk what else to do really don’t wanna start throwing vp or new lift pump at it if it’s something electrical or ac noise! Pls help. Also grid heaters were throwing a code before I unhooked idk what was wrong with them but I just un plugged them. Right now I have exhaust manifold leak at back of manifold toward pass side and a little oil or residue on bottom of turbo I guess where it bolts up at bottom? Can still push 28 psi boost when it doesn’t lose throttle she runs like a top 80-90 idles and city drives fine till throttle drops on highway
Edited by Beepbeep24v
Add
