2nd gen PCM functions
- Replies 11
- Views 12.6k
Laidback 4 posts
Me78569 2 posts
Tractorman 2 posts
Mopar1973Man 1 post
Popular Days
ensure you troubleshoot before you attempt to solve. Did it slip at 75 mph before your trans rebuild?
Electrical noise can come from several sources - poor battery condition, poor electrical connections, poor grounds, a bad diode in the alternator, etc. There is also a wiring modification article (ca
Can someone tell me what the functions of the PCM are for a 2001 Ram 2500 4x4 automatic? I recently had the transmission rebuilt and the ECM replaced but the transmission seems to be slipping at 75-85 mph. I was told by the guy that replaced the ECM and programmed it that it’s a PCM issue but when I called trying to find someone to replace or repair my PCM they are telling me it is an ECM issue. All of my gauges seem to be working fine but my heated seat buttons on the dash light up when I crank the truck and they will flash for a while and then the hi light on the drivers side stays on all the time. The heated seats haven’t worked in a couple of years. The only issue that I know of right now is the transmission feeling like it’s slipping when you just barely give it any throttle it’s not wanting to stay in a high gear.
