- Replies 15
- Views 1.8k
Mopar1973Man 4 posts
Nekkedbob 4 posts
Tractorman 2 posts
Great work! 2 posts
I am still using my original Bosch alternator. Two sets of brushes, one bearing set, and still original diodes. Still passed the AC voltage test last time I checked. One thing I have done different
I don't think it is a bad idea. My view is a bit one-sided because my only experience is with a Bosch alternator. I ran that alternator for 215,000 miles before I replaced the brushes and bearings.
All I can say is I’m still running my original Bosch and now at 340000 mi.I’ve never done anything to it and it’s never exceeded recommended A/C ripple either, I also never have disconnected grids as
I like so many of us go through alternators. I was doing some research as to stop this problem and ran across a rectifier with Avalanche diodes. What little I can find about them is that is what the newer cars are using. From what I have found these will clamp the voltage spike caused by large current things like when the grid heaters turn off. What I have not found was the specs for the voltage that they clamp to or if they will help with the ripple that causes our problems. This is call out to anybody out there with more knowledge then me or better search results if these would be a good choice.
