- Replies 16
- Views 3.1k
hdpwipmonkey 4 posts
Mopar1973Man 3 posts
IBMobile 3 posts
Doubletrouble 3 posts
Popular Days
You don't need a crimper. I soldered all the cables into the lugs with a small butane torch and rosin core solder. You can use a propane torch on low. I didn't use a breaker. I di
Amazon 150 amp circuit breaker https://www.amazon.com/STETION-Circuit-Trolling-12V-48VDC-Waterproof/dp/B07TBF1GVK/ref=sr_1_10?crid=3ICPSG3HB92FB&dchild=1&keywords=circuit+breaker+automoti
Solder the ends. I know some dont agree with that but I have yet to have any problems with mine from the ground mod or making new battery cables. If you do want to crimp them thats fine too. But you w
So I did the WT ground portion but I want to finish it and move the alternator cable from the PDC to the passenger side battery. My original plan was to use the original cable from the alternator and cut it and run it to a circuit breaker then use more of it from the circuit breaker to the battery. This will involve buying the circuit breaker, some lugs, and a crimper for the lugs. While doing some research on which size lugs I'd need to do this job I ran across that custombatterycables.com makes an 18 in 4 gauge wire with a fusible link to run between the alternator and passenger-side battery. The price for this cable is $31.75. So now the question, do I buy all the stuff I'd need to make my own cable or should I just buy the one from Custom Battery Cables? To build my own I know it'll be more than the $31.75 for the pre-made cable but if the fusible link goes then it'll be another $31.75 for another one.
Another question, if I make my own any one know what size lugs I'll need to be able to reuse the original alternator cable?
Thanks.
