- Replies 30
- Views 17.4k
jltait 13 posts
That Guy 7 posts
AH64ID 6 posts
Mopar1973Man 3 posts
Yes reducing the EGR is a great idea, if you are able to. Duty cycle helps with that too.
Agree with everything above
The bad side to the EGR... The fact is you just recirculating exhaust back into the air mixture in the cylinder to hopefully reduce the peak flame temperature which will make the NOx less. Bad part id
I thought I did the right thing picking up a pre DEF 2011, but after a failed EGT sensor sidelined my new (to me) 4th Gen I started doing some reading. Some of the forums say the DEF trucks (2013+) are much better for the engine than the pre DEF trucks. Is this true, if so, what are my options to ensure my pre DEF truck make it to 250-300K miles.
