- Replies 8
- Views 2.1k
Mopar1973Man 2 posts
Me78569 2 posts
NIsaacs 1 post
Doubletrouble 1 post
I just pulled in from my 11 hour drive from Chattanooga with 15k in tow. I have found that the truck bounces in a resonance when on a poorly paved interstate while under throttle, no issue when coasting. If I let off it stops, back on and it starts again. Slow down to about 35-40 and it goes away, not really feasible on a 70mph interstate as the bad surface may go on for miles.
The best way to describe it is feeling like the shocks are completely gone, but it only does it on very specific buckling highway. I can hit large bumps and bridges, and no bounce or anything consistent with bad shocks. The speed at which it happens is based off how far apart the buckles are, usually about 4-6 times a second at 65mph. Uphill/downhill has no effect, only road surface and throttle, exhaust brake does not cause it.
Because it only does this when under power and with a heavy load, I'm thinking axle wrap may be an issue. The more throttle applied, the worse it is.
Ideas? In my mind, if it is axle wrap, maybe track bars would fix it. Maybe the shocks aren't strong enough?
