- Replies 16
- Views 4.9k
dripley 4 posts
Dieselfuture 4 posts
DieselJake 3 posts
Mopar1973Man 2 posts
Popular Days
This would be a normal symptom for what you did (opening the drain in the filter housing). Air was introduced to the fuel supply for the injection pump. When you started the engine two hours later,
Also get a fuel pressure gauge. That will let you know if your pump is going bad, even a cheap one. And always use genuine parts.
My guess is your lift pump has been dead but since you had pressure in the line the VP was able to pull fuel. Once you released that pressure you don't have the lift pump to build the pressure back
I have a 1998 Dodge Ram 24V Cummins 3500 2WD Dually. Yesterday I moved the little selector on my fuel filter housing and pushed it down releasing a little diesel. I stopped after about 5 seconds. I did that with the truck off. After about 2 hours I went to leave and the truck turned over, fired and then stalled. Since then it won't crank.
I have watched some YouTube videos about priming it, some people saying I let air in the system other saying my VP is toast and honestly I am new to Dodge Cummins so I am not familiar with what to do. This is what I've done so far:
1. Turned the truck over about 45-50 times, it won't fire. I killed both batteries.
2. Charged the batteries and cracked the fuel injectors just 1 and 3. Turned the truck over about 20 times: no fuel came out.
3. Opened the two little pressure screws? On top of the fuel filter housing and topped the fuel filter housing with diesel. Attempted to turn it over 10 times: no fire.
4. Cracked open the fuel line nut LEAVING the filter housing going to the VP: turned it over about 10x: no fire and no fuel came out.
5. Cracked open the nut on top of the fuel filter housing coming FROM the lift pump, attempted to turn it over 10x no fuel came out. Took the nut out, attempted to turn the truck over and it stayed bone dry got no fuel and no start.
6. Turned the key to the on position but no start and listened for the lift pump to engage: silence. Turned the key to the on position, then bumped the started, listened for lift pump to engage: silence. Checked the fuel pump relay and swapped it with another relay, checked fuel pump fuse: nothing.
7.Everyone is telling me to go purchase a new lift pump now and it seems like that is the problem I guess. The lift pump is dead silent, its not filling the fuel filter cannister, but I cant seem to think something else is going on here...why in hell would it suddenly die just because I released the water/fuel valve on the fuel filter housing? What do you all think? Thank you
