- Replies 9
- Views 4.4k
Mopar1973Man 2 posts
jlwelding 2 posts
Dieselfuture 2 posts
NIsaacs 1 post
Up date - rear main is dry as a powder house, new transmission front seal leaking. Pulled trans got it out on the bench investigated a little closer and input shaft bearing has wear marks on race and
Which type seal did you use, rubber or teflon? The teflon one goes on dry. The biggest issue with a rear main seal is getting the retainer centered with the crank, block and oil pan. Take a few extra
Even with a #5 injector line leaking will make a clutch slip. I'm watching and learning because someday I know I'll find a guy that needs a crank seal next. Matter of fact I should dive in
So I replaced trans, flywheel, clutch and pressure plate and while I was there I replaced the rear main seal. I noticed it leaking very little over the pasted week then I took it for 350 mile round trip and its leaking bad now. Got new seal and going to do it again, any tricks to the trade here? I know the front seal has a sleeve to install but nothing on the rear?
I thought I would grease it up this time.
