- Replies 9
- Views 1.8k
JAG1 4 posts
dripley 2 posts
AH64ID 1 post
Dieselfuture 1 post
Popular Days
Remember if you get too much metallics in the grease between the tone wheel teeth the the ABS will freak out and set the ABS and BRAKE lights. Not something I willing to suggest. The tone wheel should
I have never greased mine. Lost both the OE ones within a couple dats if each other at 217k and change. Easy to remember that mileage because my ECM failed about 500 miles later. Took those out around
I actually drilled and tapped for a grease fitting facing 90° towards rear on both sides. Tiny hole all the way through and a 1/4" one for the fitting. First I do the fitting then drill through, this
Dieselfuture is the one who first brought it to my attention of greasing the front hub bearings thru the ABS sensor hole. Now on my third front hub replacement yesterday in a couple years to both my 2nd gens you tend to get tired of the expense and time. I was only in there to replace the brake pads and discovered a rough spot in the wheel hub bearing. The only way to tell was to turn by hand with the wheel, the caliper and rotor off because just a few weeks earlier I had checked for looseness in the wheels, so on I went with a new Timken hub. This time they got me for over 300 bucks because I needed one right away to be up and running by Monday.
Now before removing the old hub with the rough spot, I removed the ABS sensor and pumped a bit of grease down the hole while turning. Wow that really did improve how smoothly it turned. Thanks Diesel future
. I went on to replace it anyhow and found leaking caliper pistons.... on an on!
Oh yeah, no I didn't use chicken grease Dripley, I know how you are about animal rights, but I am greasing all four hubs on my trucks from now on.
