Happy holidays to all !!
Here's hoping '21 will be better !
Sorry for another mpg question and I'm sure this has probably been discussed to death somewhere??
  So I've owned my truck for almost a year now, I don't drive it much, mainly bought it for hauling camper, dirt bike and such, I don't think I've put more than 6 - 7 tanks of fuel thru it, maybe 3 since I got quadzilla.
 Was I mistaken thinking I was going to get better milage with the quad?
 I love the way it runs, and I drive pretty conservitaly most the time and I have yet to get over 12 mpg ! That was before and after quad, no difference other than power, which is nice but??
 Now I'm still extremely new to the diesel world and all these charts and graphs of timing, fuel curves, volumetric tables, etc.. just seem to make me more confused 🤔😵
 I'm really wondering if I should have just got the edge comp and been done? I was reading somewhere moparman was getting an additional 7 - 8 more mpgs with just the comp box. Oh well, too late now.
  When I'm not towing I'm usually driving mostly city and running the"daily driver with meat" level 3, I really like the tune, but does anyone have a good economy tune/tunes like one for city, low speed driving, and one for hwy with stock to 75 hp injectors? Time to save for bigger ones? Should I be driving with a higher or lower level?
 I kinda remember doing a idleing load test right after I got the quad to test injectors and everything was fine, assuming that test actually works?
 Or just maybe some advice/opinions on what's happening here? Or some easy to understand settings with small words in bold type, LOL!
      Thanks!
  • Replies 42
  • Views 5.6k
  • I guess it's just a good thing I decided to use the dodge mainly for towing, the dodge vs my gmc would've made zero sense economically as a daily driver even if it were only the cost difference in fue
  • I would say Level 2, but with proper tuning I could see level 3 giving great mileage, too. I have no experience with wire tapping but Mike has previously mentioned driving around on max wire tap and g
    I'm sure enjoying the fact that I'm no longer driving 1,100 miles a week. Yeah I'm stuck driving either to Lewiston or Ontario for most stuff. Local stores have gone up in prices. Even fuel price in t
7 hours ago, dieseldon said:
I'm curious what level gets the best milage regardless of tune
I would say Level 2, but with proper tuning I could see level 3 giving great mileage, too. I have no experience with wire tapping but Mike has previously mentioned driving around on max wire tap and getting good mileage. I seem to recall his wire tap doesn't engage until higher boost, like 15-20 PSI, so even when it engages shouldn't roll coal and waste fuel.
I guess it's just a good thing I decided to use the dodge mainly for towing, the dodge vs my gmc would've made zero sense economically as a daily driver even if it were only the cost difference in fuel. Although it does help boost testosterone levels, LOL!                            I'm assumeing those low summer prices were too good to last?
 Too bad there's that whole scam deal nonsense going on with diesel fuel prices! 🤬 I am old enough to remember when diesel was way cheaper than gas, but then there was really no diesel pick-ups on the road either. 🤔.... SCAM!
  Can't wait till - you know who- starts implementing the "green new deal".... NOT! I better stop before I get into trouble.
I rin the Comp but never saw a huge bump in mpg. 1 mpg more tops. I tow in level 3, 11 to 11.5 mpg, and empty in level 5 at 19 to 19.5 empty. I towed a 35' 5th wheel at 15k pounds and near 13' tall. I never believed all 3 to 4 mpg gallon possivle increases that every one seems to advertise for z, y, or z modifacation.
 This not to say you cant get yours up near 20 with Quad. Sure would seem possible with it. Just have find the right tune. That is above my paygrade.
Edited by dripley
 I drive my 3500 dually 4x4 daily. I guess I'll pay whatever fuel is at the time but I won't give up my truck. Mine is mostly stock, summer milage was about 17-17.5 mpg. I'm sure winter blend will drop it some but I'll deal with it.
Back in the day I found that if you want to get good MPG you had to limit your speed to about 55 MPH. Above that the engine load was too high and stripped off the cruise timing. Being the Edge Comp basically adds timing on top of stock. With the Quadzilla you set all your timing yourself. Just like I'm finding out on level 2 your completely stock fuel (limited to 100%). Now any and efficiency is based on timing. Just "close" timing should get you to the 19-20 MPG range with winterized fuel.
I have no doubt that Quad is better tuner with the adjustability it offers. I was able to make 19.5 mpg on a highway with the comp on level 5 mostly cruising around 70 to 75 but those left lane riders kept getting in the way. For the most part on non winterized fuel as best I can tell. Nothing is marked on the pumps out my way. with temps not dropping down to 20 very often here I doubt they need to. I was able to make a pure highway run yesterday and wracked up 430 miles just shy of the 1/2 tank mark on the gauge. Bare in mind thats about 2/3 of a tank full gone, but all the ear marks of a 19.5 mpg run for me. first long run I have made in a while. Still running 600 or so miles a week just on secondary roads. Between that and idling to stay warm or cool my mileage is in the mid teens,14 to 15, on a good week. But riding around a 7500 pounds I am not complaining.
I'm still a little confused about #1 and #2 diesel, I understand in a nutshell they're different cetane but how about efficiency? Is #2 worth the extra forty cents per gallon, the difference between flying j (40 cents more) and Fred Meyer is approx one block apart. What say you?
I don't plan on giving my truck up either, but when I have a nice cushy park avenue that I can operate for half the cost and no wear and tear on the truck that'll be my daily driver, fortunately don't need a truck for work, etc.
 Moparman, when you say "close timing" what kinda numbers are you talking about?  @45, @55, 65, 75, 80?
With or without head studs make any difference?
   Thanks!
I dont see #1 out my way. Why it would cheaper than #2 I dont know. Out my way it is all #2 and #2 blended with Bio. I dont see as much of the blend as I used to. Love's carried it for a good while but it has been very hard to find a pump labeled for the bio blend. Plus Love's is now about 10% higher than most places. Around $2.50 at Love's and about $2.25 a gallon most every where else. They used be in line with everyone else.
Like fuel prices out here are about $2.709 for diesel. On my last trip to Lewiston, ID I saw $2.409 at the Indian reservation. Good price then drop into Lewiston its $2.559.
There is Murph's oil outside of a Wal Mart on the way work. Had to stop at Lowe's near there about 2.5 months ago and they diesel for $1.71 while it was still $2.25 at home and $2.15 neat the job. Don't know why it was so much cheaper there. But over the past 2.5 months they slowly went back up to the average price everywhere else. It was fun while it lasted though.
I'm sure enjoying the fact that I'm no longer driving 1,100 miles a week. Yeah I'm stuck driving either to Lewiston or Ontario for most stuff. Local stores have gone up in prices. Even fuel price in the valley is high. So we attempt to round up every ones shopping list and make a full day of getting supplies about every other week. Yeah it was nice when I was running @MoparMomback and forth I could do shopping and part gather every other day. (Tues, Thurs, Sat.).
12 hours ago, Mopar1973Man said:
Start at about 19° @ 2k RPM in cruise state.
As for cetane, higher the cetane the lower the BTUs. Lower the cetane the higher the BTUs.
Thanks moparman! I'll try to dial that in.
I was just trying to figure out how flying j thinks their fuel is worth 40 cents more per gallon? Maybe if they were a mile apart, but they're right next to each other, flying j has a neon sign advertising #2 diesel, fred meyers told me they don't know what's in theirs!
No biggie, just one of those head scratchers 🤔 they both have a lot of traffic, flying j has big rig pumps.
 (Federal way, right off I 84)
same thing with Love's. But I guarantee those trucking companies are not paying the high price
Again Quadzilla Tip.
Figure your max timing out first. Then stack your cruise timing on top.
Figure like I do in the winter time with high cetane I've got to back off the timing since the fuel lights super easy. Here is what I would suggest. This is a +4° step timing starting at 13°.
1,500 RPM - 13°
2,000 RPM - 17°
2,500 RPM - 21°
3,000 RPM - 25°
Now figure your cruise timing on top. Set your Light throttle Timing Adv. for +2° will give you 19° at 2k RPM
1,500 RPM - 13° +2 = 15°
2,000 RPM - 17° +2 = 19°
2,500 RPM - 21° +2 = 23°
3,000 RPM - 25° +2 = 27°
As for the cruise timing for load value I usually watch my flat ground engine load at 65 MPH cruise set and then maybe at the most add 2% on top. I float about 19% to 20% engine load right now. Add the +2 to that and now the cruise limit is 22% then it drops to the load based timing.
This should get you started...
Thanks again for the help!
I didn't even realize you changed timing during winter.
It's too bad quadzilla doesn't explain their product a little better with youtube videos, more in-depth instructions or?? , just generic bare minimum, leaving people like me scratching their heads not knowing up from down. I really gotta wonder if they even understand it as well as you?
Strange how quadzilla doesn't talk on forums anymore, at least since 2017 from what I can tell? Or maybe just on newer model forums? I really haven't looked that close.
 I hope people keep buying their stuff and they're around for support for a good long time.
Moparman, just to be 100% clear, when you say cruise limit does that mean light throttle limit? I'm starting to think the timing parameters terminology has changed over the yrs?? Kinda confusing when you're talking about cruise timing and cruise psi, etc. Not exactly sure on max load timing either or low psi timing reduct?IMG_20201231_200511_copy_1500x2000.jpg.ba4ea00187869fe7df4e20454b939d4d.jpg
Here is my timing parameters, please let me know if you see anything off or strange,  tthanks !
P. S. Happy new year!!
Yes. That confused me in the past, too!
Other than the Adrenaline, my truck is stock (see my signature for details) with a dinky HY35 turbo. Since the factory timing is over 13 degrees at 1500 RPM and I don't need help getting the turbo spooled, I started my table around 13.5 or 14 degrees timing. I also set my "Light Throttle Limit" to 40% so I can stay in the higher timing (19.5-20 degrees) while cruising on flat ground at 70-72 MPH. My mileage is MUCH better since I've done that. EGTs are lower, required throttle input is lower. And that's before I changed the rear diff carrier bearings.
It's great on a Sunday, etc., to do laps on the highway, back and forth with different settings to see what changes. Low traffic and cruise control helps minimize variables pass to pass.
I think this tank I'll be well over 19 MPG, but watch it drop to 16.5 🤬🤔😆
It is explained in as much detail as I could :)  There is even a youtube video..
