Friends truck stumbles and dies
- Replies 6
- Views 2.9k
That Guy 2 posts
Mopar1973Man 1 post
JAG1 1 post
Dieselfuture 1 post
Popular Days
One to look for is a cracked pickup tube. I've seen 2 different truck now that fail after about 1/4 to 1/2 tank. The corrugated tube for the pick up could crack all one corrugated tube and its hard to
Sounds like it's sucking air, once tank had more fuel no problems.
fuel module screens clogged or sucking thru old in tank lift pump? Watch that inlet screen sometimes placed inside the inlet side of the aftermarket Raptors. Don't know about other brands, but tends t
I feel special today for having a reason to post in the 24V section, but I digress.
Friend bought a 01 2500 2wd auto and it has about 310k on it. The injection pump and injectors had been replaced just before they bought it. $3000 and had a "bottom end knock" which turned out to be a cracked flex plate.
So, the fuel pump went out on him and he replaced the in tank unit and the block mounted pump. Ran fine for several days and then it stutters and dies. He bleeds up to the injection pump and it fires off. Makes it about 3 blocks and does the same. Won't fire back up. (He is one of the duller knifes in the drawer but learns his lesson. Hard to get all the information out of him because he doesn't associate things.)
Calls me, I show up tools in hand. Getting plenty of fuel to the injection pump. Was only coming out on the No 4 injector line. Wasn't getting a drop from 1-3-5. Couldn't get to No 2 and didn't try 6. Electrical checked out so I moved onto fuel, took forever to bleed so I gave up. Disconnected the grid heater and shot some ether into the turbo with the lines cracked. 10 seconds in, fuel is pouring out of the lines so I tighten them up and it idles. Has the odd stumble. Shut it down after a few minutes. Won't fire on its own. Fire it up on ether again and he fills the tank. The stumble stopped once some fuel was in it again.
Now, I suspect he may have gotten the supply and return lines crossed when he installed the new sender/pickup assy, or maybe the new sender is bad and sucking air at 3/8ths of a tank. Am I wrong in my assumption? Other ideas? My first time turning wrenches on a VP44 truck. He did make it 20 miles back home without incident.
Edited by That Guy
