- Replies 19
 - Views 1.7k
								Doubletrouble 9 posts
								Dieselfuture 4 posts
								JAG1 3 posts
								Mopar1973Man 2 posts
Right, you only throw full beers to people you like. Lol
I hope @Dieselfuture knows that already. Empties for launching and cab corners.
Today the wife an I had some running to do so not alot of garage time today but I did get the lift part somewhat figured out. I will refine things and make improvements as I go. I'm sure I will run in
So I was in the garage today, bored. Had a 44" John Deere snow blower sitting around for a while. (Long story) and decided to see if I could adapt it somehow to my Kubota B5100 lawn tractor.
Tractor has a vertical PTO pulley and clutch up front and the blower has a horizontal belt drive so didn't see why this couldn't happen. I began to fab up a mount on the tractor to connect the quick connect hitch for the blower. So far so good. Have to fab a couple mounts for the idler pulleys to transition from horizontal to vertical to drive the blower. Then work out the lift system using the 3 point in the rear for now. Once I have the brackets and such mocked up and welded I'll clean them up some. The pics below are just rough mock ups right now. I think it'll work though. Just thought I'd share.
And yes,.I know. The garage is a crazy mess.
