- Replies 15
- Views 2.5k
comanche79p 6 posts
Dieselfuture 2 posts
LorenS 2 posts
Joe_Pool 2 posts
Popular Days
Where are you reading pressure? (Between FASS and OEM filter housing, after OEM filter, ...). It could be a bad pressure sender, possibly affected by the cold or "hammered" by the VP44 (not enough s
The FASS folks indicates I have a ruptured diaphragm. Sent them my serial number to see if the will warranty it. I bought it in 2013 from Geno's. Thanks for all the help.
My fuel pressure has been acting crazy. Started gradually increasing from 16 lbs to 27 lbs.
I thought at first that it was due to cold fuel. I live at 9500 ft.
Had this system for about 35,000 miles or so.
2001 2nd generation with DDRP Fass 95 mounted near the fuel tank.
It did the same thing a while back and I got the pressure adjusted back to where I wanted it. Now I have to try it again.
Is it the ball and spring in the Fass pump you think?
