- Replies 26
- Views 6k
Mopar1973Man 8 posts
Jeff Eady 7 posts
Me78569 3 posts
ddmk6 2 posts
I went ahead and payed extra to have the new head Studded. Not really sure how much that helps but it was suggested. I appreciate all of the help. I am asking the guy that I purchased it from wha
I have known the the guy for years but he did date my sister n law for a few years! 🥴 Previous owner just called me and said he bought the 125hp from industrial injection. He said they were true i
then I think you are good, throw the quad back on load up mikes tow tune and see how it is.
Hello guys,
I recently purchased a 2001 Dodge 3500 5.9 5spd to pull my equipment. My equipment weighs roughly 15k plus my 25ft dual tandem axle trailer. The guy that had the truck installed a 62mm turbo, 125hp injectors and adrenaline tuner. On level 3, the truck black smokes so bad that I can’t even see my equipment and don’t really build much boost until about 2k rpm. Took it to my mechanic and ended up having a cracked head. Ended up getting a new head, changed the tuner to a edge and still have the same
issue with to much smoke and not enough power. Mechanic is suggesting to go with a smaller injector size. Any suggestions? Thanks
