- Replies 14
- Views 2.8k
wil440 5 posts
Mopar1973Man 4 posts
LorenS 3 posts
AH64ID 1 post
Popular Days
Still that about the only time I've seen coolant getting burnt carbon back into the cooling system but never lost coolant which was weird. As for Dodge never seen it yet with EGR leaks (coolant vs. ex
Let the truck cool down completely over night. Now take a coolant pressure tester and pump the system up to 16 PSI and let it sit come back in 30 minutes and look for the coolant either on the floor o
That is so but a low pressure part like induction is then followed by a high pressure compression and ignition, it would pressurize the cooling system and also cause combustion gas to be in the coolan
My truck has consistently eaten coolant since I've owned it, 65k miles or so. If it isn't leaking (can't see or smell it), is it possible for the coolant to find its way into the combustion chamber but not have exhaust gas get into coolant?
1/4 - 1/2 gallon a month, new radiator and obviously coolant last summer. Coolant looks new (not surprising considering how much I add).
