2006 Dodge Adventure!
- Replies 22
- Views 5.6k
Mopar1973Man 8 posts
AH64ID 6 posts
Doubletrouble 4 posts
Tractorman 2 posts
Here ya go, a light and a magnifier. https://www.harborfreight.com/fluorescent-magnifying-lamp-60643.html
It's a rather common and known issue with the tach's on the 06 clusters. The soldering fails and the tach is usually the first thing to fail or become erratic. I've never read about AC noise as an iss
I hear ya. I'm 50 years old and high milage myself. I don't solder so well, it works but isn't always pretty.
Well since I made the move to process to purchase the 2006 Dodge from the bank...
It getting more and more reliable for driving back on forth to work. I'm looking to getting tires soon since the passenger side front is slow leaking and the rubber is getting weather checked after sitting for at least 3 years. I've got 275/70 R18 on it right now. I've got 3.73 gears I'm thinking of going up to a 285/70 R18 to bring the tach down a bit more. I'm not sure I can even trust the tach info yet being it some time shows me idling at 300 RPM and other times at 800 RPM. I'm starting to think there could be a AC noise issue with the alternator.
I've got electrical to do on the bed and tail light yet its still just cobbled together for now. I need to wire in the goose neck plug and the bumper plug for 7 pin.
Since I bought the tool boxes I've been adding more and more weight to the truck. Just like yesterday I spent $100 on rear axle sockets for pulling nuts on the bearings. So I want to gear this truck just about like what I did with the 2002. I wanna be around 1,800 to 2,000 at 65 MPH. Doesn't take me long in a day to put on a few hundred miles.
Has anyone pulled a HVAC box out of a 3rd gen before? I know I've got to look at mine being some of the stepper motors are cycling and having trouble moving doors. I know the evaporator is partial plugged up with caked dust air flow is poor.
As for doing the wheel joints. Way easier way is you cut the trunion out with a torch. Now the bearing arms fall out and you can drive each bearing cup inward on all of them. Moving one cup at a time vs pressing two cup back and forth is a pain in the
. Took me all of about 10 minutes to cut the trunion and then drive the caps inward. Used a hone brush to clean the holes up a bit and pressed the new u-joints in. Yup the shaft on the passenger side was just needing more force to pull out. Been in a long time I guess.
