Replacing head gasket
- Replies 123
- Views 25.3k
Tex_usa 40 posts
Mopar1973Man 29 posts
dripley 10 posts
Tractorman 9 posts
Correct. You must place the head then install the studs. The longer studs go on the exhaust side of the head. There is one that won't fit between the cowl and the head. I use a floor jack and lift the
What he said ^^^ I used a shop vac when scraping the gasket off, that way everything was sucked up as soon as it was lose, it's a but of paint in the but to have a scraper in one hand and
Not entirely sure on the o-ringing. I don't know if its a static diameter or if the o-ring diameter is based on the cylinder bore diameter, I don't think it is based on just sending the head out to pl
Ok this is my first time posting here so if I'm missing something please let me know.
I'm relatively new to the diesel world but have read multiple posts on here as well as other sites about replacing a head gasket.
My first question is do you need to resurface the block in addition to the head when doing a hg replacement on these 24v cummins? Also Is it common for the head to be cracked at 200k
This is my dd and I noticed that I am leaking oil right where the head and block meet. I cleaned it up and drove it some more and it definitely looks like it is leaking from the head gasket.
I would need to replace it during a weekend and want to make sure I will not have any surprises that I am not aware of.
I've looked at getting a new head with rings but I don't know what all I would need to do in addition to just a hg replacement.
Engine is from a 2002 2500, has S363/68/12 with 7x.010 Injectors and a quadzilla adrenaline.
