Garage LorenS 2018 Ecodiesel Thread
Today I picked up my new to me 2018 2WD Ram 1500 SLT with the Ecodiesel and 8-speed auto. For a newer vehicle it's a darn low trim package, even has manual seats! I think it's supposed to have heated mirrors. It supposedly came with tow package, but there's no 2" receiver, so...? Has 7-way plug and factory brake controller.
Dash readout claims to have only 800 hours combined idle and drive time, but has 50,500miles! Something isn't right. New engine or ECM already?
A 49-state tune is high on priority list, from Green Diesel Engineering. It's pretty spendy, but they have to recoup their EPA compliance testing somehow, I suppose.
So far I'm amazed at the things that seemingly aren't available, like a factory service manual, and Donaldson or Fleetguard filters.  Most of the filters are just pleated, not the fancy synthetic material!  Both oil and fuel.  Strange coming from Cummins or small block Chevy where there's a billion choices.
Edited by LorenS
Added two photos for Dripley :)
  • Replies 26
  • Views 6.5k
  • I dont know squat about what should have come with but I do know that
  • That was a step in the right direction. Maybe you will let us see the top of the truck.
  • Silverwolf2691
    Silverwolf2691
    The diesel aspect would be pushing me away from that.. too much risk for someone to just put unleaded in there and not think twice.. until it starts making noises..
I dont know squat about what should have come with but I do know that :piwwp:
I was going to snake some of the pretty pictures from the dealer's website but they're already taken down :duh:. I'll get some up later, may edit the post to do so.
Here's the "hitch"...? A Curt hitch is also on the short list of expenses.
That was a step in the right direction. Maybe you will let us see the top of the truck. :whistle:
Two photos have been added to original post.
I must say it's a little underwhelming in the giddy-up-and-go department compared my 01 with Adrenaline on Level 3. But, it also rides like a cloud compared to the '01!
Edited by LorenS
10 hours ago, Mopar1973Man said:
Very odd design on the engine. Would of been better with 4BT Cummins.
Can't really disagree on that.  Or at least some other engine or engine design with a longer track history of longevity.
Not sure if this engine has been around long, but at least it's a USA company:
https://demanddetroit.com/engines/dd5/
It does weight 1200 pounds, so that would be a big issue in 1/2 Ton class!  The 36 month / 250k mile warranty would be great for you hot-shot guys.
Edited by LorenS
800 hours means an average of 63 mph, so it's possible that someone spent the life of the truck on the interstate. How many idle hours?
Odd hitch setup for sure. Have you looked up the window sticker?
Edited by AH64ID
It's a TOTAL of 800 hours, that's what's crazy!  The idle hours are over 200, so the driving hours puts it at over 86 MPH average speed!  Clearly something ain't right.  CARFAX showed no history of something like this, but there are a couple of dealer entries of "vehicle service".   Other dealer entries were very specific.
Yeah that doesn't sound correct. I wonder if the drive hours have reset, as I've heard about on some of the HD trucks with the standard dash.  It always happens at 1092 hours. Idle hours don't reset. So that would put you at 1892 hours and an average of 26 mph.
That's terrible!  I sure hope not for the sake of my DPF, etc.
10% idle time is still good thou, so I wouldn't worry too much.
I think this might be the hitch you need.. Reese towpower class IV
It looks like a chrome packaged tradesman.. that would explain the manual seats..
thought the same thing when I had mine. but hold the thought until after the tune.
Sorry but the EcoDiesel is by VM Motori not Detroit. It's a 3.0 v6.. nevermind.. reread and I think you are implying an option not what it is.. Detroit DD5 is a 5.1L 4 cyl.. 4bt on steroids right there :stuned:
How is it odd? genuinely curious.. and the 4BT or R2.8 probably would have been better, agreed.
I wonder what one of these Kohler engines costs.  Would be WAY more horsepower than my 1986 6.2L Blazer!
https://kohlerpower.com/en/engines/product/kdi3404tcr-scr-141hp
I think you're right.  Curt makes something similar.  When I looked up the 'scratch and dents' on Amazon, it wasn't much more to get a full Class IV Curt hitch than the little bolt-on deal you show.  I don't mind the hitch being visible versus hidden behind the bumper, so I ordered it.
My GreenDieselEngineering.com EPA compliant (49 state) tune has been ordered!  A lot of money.  I wish I could just delete it (or at least turn off EGR), but with the EPA cracking down on dealers and installers, it's just a matter of time until the vehicle owners start getting whacked, too.  If I never left Missouri or Kansas (though that's still crossing state lines), I'd strongly consider it.  With my 2001 if they confiscate my Adrenaline I can put the plugs back together and drive on with my stock injectors.
This tune is supposed to be quite worth it in the long run for DPF life and reduced regens.  At less cost than a replacement DPF, I decided to buy this tune.
I wonder if the 3.0 is like the HD’s and will regen based on run time or  DPF status.
On my 2018 I’ve never seen a regen trigger that wasn’t based on the 24 hour max time
between regens. I had one today. Often my DPF back pressure doesn’t change much from pre regen to post regen based on how I drive it. I’m not sure I can adjust that max time between regens with tuning software, so it makes me wonder if the 3.0 doesn’t have it or if they simply reduce DPF fill % for certain types of driving.
My 2018 EcoDiesel would do a passive regen while going on a longer trip, but would take like 2 weeks to load up the DPF and pop the message on the dash in the winter from warm up. Yeah, short trips, guilty.
My OBDlink LX can read the dP on the DPF, so I'll watch that to see what I can decipher. I'll look for time between regens data.
Kinda makes you wonder if this was a rental truck, like from enterprise or something, They are known to take hitches off so people don’t tow with them, The mileage is in line with their trade out criteria too
