Few random questions..
- Replies 55
- Views 10.5k
Silverwolf2691 23 posts
Mopar1973Man 13 posts
Dieselfuture 7 posts
IBMobile 3 posts
I on the other hand used the hell out of mine trying to make custom valve seals . Btw they are still holding up
What I have always looked for when looking for engine performance in a vehicle is, "what will be the engine rpm in a specific gear at a specific highway speed that I would drive at based on a specific
to be compatable with all trucks without extra cost and install requirements are you talking about lines ~69-83 ish?
Have a couple random questions about my truck:
1. On start up, the puff of smoke is getting thicker and bluer. It also has a slight oil smell to it. Idling for a bit also starts getting an oily hint to it as well. I'm assuming that this is either turbo or valve seals. I don't think its valve seals because those are only 4 years old from when I rebuilt the head.. Turbo is the factory hx35 with 213k on it so id think its getting time to rebuild.
2. While sled pulling, in my Quad's datalogs I have found that the canbus fuel is dropping off a bit then back up to 4095. I don't have back downs, and throttle stayed at 100%. The green vertical bars are canbus, the yellow line is load, and the brown/copper one is throttle position. this is my most recent sled pull. It was this past Saturday, the 7th. 200ft track and stupid sandy, no grip. The dip in the middle was me letting off to see if I could get any more traction but I think it cost me distance instead. In the last half of the pull after me letting off the throttle and getting back on the fuel keeps dropping a bit.
Dark blue is rpm, gray is egt, peach is timing, light blue is boost
3. after my pull the quad showed -40 for coolant temp then started reading again. I have mopar mans high idle kit but the bone heads at the dealer didnt actually turn it on despite having the tsb in front of them, don't know if that makes a difference. I haven't had a chance to look thing over yet to see if I melted something or if something is loose.
4. My sled pulls seem to never register over 30 psi on the Quad, even though my isspros show 35-38.
Edited by Silverwolf2691
premature posting..
