- Replies 26
- Views 3.2k
Myvp44hatesme 6 posts
JAG1 5 posts
Mopar1973Man 4 posts
wil440 4 posts
Popular Days
Sorry to hear about these problems and poor experiences. BD (or it's owner) is a part owner of VALLEYFUEL on the west coast. http://www.vfidiesel.com/ They are affiliated with Bosch.
At $6700 in lost $$$ I'd be personally taking that VP back and it wouldn't matter how far they were away, in fact I'd drive the truck to them with the crusty VP that's on it now and demand they fit th
Midwest Fuel Injection is one of them I can't remember the second one right now. That was a sign of the being stuck in full advance when it get loud and rattles and has no power. I lost
ok here we go,
I completed my swap about a year ago and everything worked great for about 9 months. all of the sudden one day im driving down the road and the van just stops!. it was like someone reached over and shut the thing off. after getting it towed home i followed the diagnostic procedure for the vp44 and after hooking power and ground directly to it i found that it was indeed dead and would not fire. so simple enough i order a new (reman) vp from a local parts dealer and when it shows up im immediately put off by it. it had silicone caked on the harness where it goes into the psg and had dirty finger prints as well as dirty hash marks where the fasteners hold it to the timing case. it also had a wire tap hole on the harness aswell as an exposed connecter on the other wire. just a but connector with no insulation on it. so i figure whatever to bad it probably works fine and i need to drive so i throw it on. well needless to say i had all types of bad symptoms. timing falling out randomly, engine gets loud and rattles bad no power, cutting in and out, partial pedal at %26 throttle, horrible loping at idle, not good. so i call bd diesel and they made me buy a new pump again! they would not take it on return even though the rma number for that pump stated that it had been sold and returned by someone else for all the same reasons. yes i sent it back to them to send to the reman facility and no i never got my money back, $2700. but either way i get another pump and thinking my problems are behind me i switch them out. all of my symptons have gone except for the partial pedal issue. now the truck that i took the motor out of had the ac noise issue with the trans (something i didnt realize until recently) so then i figure that the alternator must have made a ton of ac noise and whipped out the psg on the vp and when that happened something must have hurt the computer. so before replacing the computer i remove the wiring harness and cut the loom completely open, inspect everything, reloom, no issues found. i switched the entire apps assembly off of a friends truck that is known to work, no help. i scanned the computer it came up with sensor low voltage on the map, cam, and timing failure on the vp. so i take the van in for diagnostics. they told me to re do all of my battery cables and fasten them down properly. my new replacement alternator from napa was making ac noise so i got a nippo brand new non reman from my local radiator shop, they also noted that my fass ddrp wasnt keeping up and that the cam sensor was throwing some funny numbers. so i installed my fass165 and mini sump, redid the battery stuff, pulled the injection pump and replaced the cam sensor did everything that the diesel shop told me to do knowing full well that it probably wasnt going to fix the issue but i had to try. well needless to say it didnt change anything so finally after alot of searching i found a good used 2001 ecm that came off of a running truck that was p pump swapped. the truck was an 01 with a manual trans perfect match. i put the computer in today and absolutely no difference!! ive replaced everything! more then once! i have not hooked up the wire tap or used the tuner for anything except for monitoring. ive tried to run with the tuner completely unhooked. im at a total loss at this point. either ive got 2 bad reman pumps in a row (which i doubt because partial pedal doesnt seem to be a common pump issue) or i need to un install the harness again and continuity check every single wire. but the questions just pile up. why is this happening and what could possibly be causing it? why did this issue start when the first pump failed? is it possible that the ac noise damaged another sensor somewhere and the diagnostics people didnt find it because its intermittent? my van is an ex ambulance is there ghosts in my engine? is there anything else that could cause partial pedal aside from the electronics? anything mechanical? im so unbelievably stumped. the other symptom worth noting is that when it idles to temp when you first take off it wants to die like it has no power until you limp it along and run it up a bit. anyway thank you to anyone who is listening and if you have any advise for me id love to hear it. at this point i may have to p pump swap if i ever want to get to work again :0
