01 RAM 2500 Heat Exchanger Coolant Lines.
- Replies 13
- Views 10.9k
Lots of air compressors use copper tubing. If you're really worried about get type K, it's the thickest wall among the common varieties. Used for HVAC and that's a pretty high pressure.
I think you will be ok pressure wise. Hag
Anyone have an aftermarket supplier of the lines that connect to the side of the HE (coolant lines/metal tubes)? I am going to keep the HE in place but want to replace these lines as they are 21 years old and starting to leak. Ideas?
Bruce
