- Replies 8
- Views 1.6k
jlwelding 2 posts
Doubletrouble 2 posts
Mopar1973Man 1 post
Me78569 1 post
I use them all the time, they work great ensure you have a good stable temp heat gun and don't have tension or torqueing on the wires when you apply heat. I do like to use heat shrink as a 2nd layer o
Get a box of Deutsch connectors, the DT range, fully reusable except the terminals, they are waterproof and easily used, just a 90 deg small pick to pull one wedge out, small seal pick works great but
So very very rare I going to butt splice two wires together. I typically use like blade style crimp (male & female) to join wires so there is a disconnect point as well. I would rather solder and
I've noticed these "solder seal" wire connectors and wondered if anyone on here have used them and what they think of them.
They're the butt connectors with low temp solder inside. No soldering iron needed, just a heat gun.
Let me know your thoughts. Thanks.
