Angry & can't do it anymore, serious iQuad timing issues
So for how ever long I've had my back to going normally, I cannot get my timing and everything thing else figured out. I been talking, chatting with @Mopar1973Man for quite a bit over the past month plus and give him all the credit for getting me thus far, however I figured asking additional input wouldnt hurt.
My egt's are through the roof! 800-900* cruising 65 mph. Slight hill or Itty bitty incline 1100*. Lord help me if I wanna pass or just even getting up to speed 1500*
Oil and coolant always the same 195* give or take. Oil should be cooler. Engine load now seems to be 19-20 going 65 mph.
I think this is what I was running yesterday and this morning. I have tweaked it a bit since so...
I believe timing was 14,18,22,25,26 or some where close lol, it's been all-over the place lately; it doesn't matter it's all wrong and I'm just to dumb to fix this. Please be gentle....
20220328_062907.jpg.6feb17950491c2ffca5729ab6ee4d184.jpg20220328_063245.jpg.03460d265000fef0823d1740d5ac4565.jpg20220328_063904.jpg.265f34a3f4f0074485fffa5f5840ecb1.jpg20220328_063855.jpg.38ca2cf540cf55fdb17d4f4bc4d0c761.jpg
I seriously need all the help I can get. I'm losing my mind. I want a nice daily that has a little pep than stock, just to start. I can't get there... sig is up to date, (new IJ pump not tapped), turbo and injectors billing the big contributing factors here. I will admit that I will have to compromise something for something and big injectors don't usually help egts and mpg but come on 900-1500* and 11 mpg ??? What gives?
Oh and I really don't get any black smoke for what it is **testing purposes only**
That will later become a inevitable side effect when a race tune is born.
Idea i had.....I'd be open to doing a screen share with iQuad while driving...
  • Replies 180
  • Views 19k
  • DAP lists 6x.013 injectors as "325 HP". (325+235)/235 = 2.38.  Your injectors supposedly inject 2.38 times as much fuel as injectors normally used with that SO injection pump.   The rec
  • The way it works is from idle state aka tps = 0 to 1200 rpm there is a handoff happening that is more complex than a switch on or off.     how it works If you apply the throttle be
  • The "Dave Ramsey" and "old grumpy dad" in me says to instead buy some 150s from DAP and source either a stock HX35 or that HE351W I shared before. Would HAVE to be way less money and you could use tha
If the push rods are larger than stock, well smoking gun there.. Aftermarket sizes are 3/8, 7/16, 12mm, and i think 1/2 inch on the high end competition level.
The galling on the trunnions is an unfortunate thing that happens even on factory parts.. happened on mine with factory springs.
The blueing is normal.. its a heat treat on the ends to absorb the impact. But the softer rod keeps things just flexible enough to not crack or break. The extra mushrooming im not sure of..
Ill measure them when i get home today and see. Im thinking 7/16 just by memory visual...
Be ok running these them? Those are the more expensive part of this. Im ok if I have to buy push rods, the mushrooming does set well with me. Just dont know if its kinda normal and Ill be ok or hey you need to replace those....
Maybe some of this is part of that tick/tap I hear... IDK.
To me those look pretty stock.. :shrug: the orange by the cup kinda tell tail..
My hamilton/mantons/whatever dont make any different noise than stock. Theyre 7/16 and its QUITE a visual difference.
My OEM rods were weighing 103-4grams. 10mm? The 7/16s are 200grams each!
BTW do you guys do dimples out or in, on the bridges?
Didn't look, but mine came off with the long more oval shape to the outside. If you look at the pics it'll show what I'm talking about. Not sure why its bigger/oval on one side?? What's yours look like?
So:
Rockers = ok to run or no
pushrods= mushrooming -bad? replace?
Just consider... im running the 7 x 0.010 injectors on a stock HX35W turbo (54/6012). Even towed my RV which tipped the scale at 8,100 pounds (17,500 Gross weight) all the way to Cally. No EGT issues. It has to be something about your selected turbo. I'm more stock than you are with no issues with EGTs so makes me think combination of addons are causing your issues.
17 hours ago, Stanley said:
So:
I'd replace them both honestly.  I dont like the thought of metal shavings in the oil system.  The pushrods are not allowing the valves to open fully either.
Im gonna just pull them all and check. Most likely replace as my beginning thought was. Maybe @dieselautopower has a combo set or something, I seen some hamilton sets on the web that looked decent.
Thanks @dieselautopower
I assume that rocker set (in/exh) comes with everything ready to install just $86 x 6
Not a bad deal, Ill be pulling everything this evening and prolly give Mitch a call tomorrow.
I would also change your oil and filter.  that galling on the rockers hurts to look at.  I am assuming it has been like that for awhile, but better safe and sorry.   I would inspect the oil feed to the rockers and make sure you are getting good flow as well.  again I am assuming this has been hurt for awhile, but there appears to be oil starvation issues that caused that at some point.
Yea most likely before me, I havent put that many miles on it. I would guess the guy who had it before and that dragonflow pump was doing some sketchy stuff...
About 2 weeks ago I had the valve cover off and started engine running, Im pretty sure there is a video of it in this thread now that I think about it. Other than watching oil come out around everything like I did, is there a more "gooder" way of checking?
I gotta find my chiltons manual, need to research the torque spec for rocker bolts. Maybe google lol... I thought it was 28ft lbs but...
Pulled everything last night. All of the look the same as the first. #1 intake push rod looked like it had the biggest mushroom or flare, but all of them had it. Is the stock ones all like that?
Bridges look good to me, what's your thoughts?
Gotta get ahold of @dieselautopower this morning to give them some more money lol.
Let me know if yall think bridges are needed so I can add it to the order around 0930 (cst).
20220601_193604.jpg.16c6d7089b6ecd97d79ed9a6b5402070.jpg20220601_193157.jpg.7c392b2a65444c0b5760fa5450c58ef6.jpg
20220530_150919.jpg.d92523c7953f9367e0cffeaba55fa2eb.jpg20220601_193211.jpg.d9810c2f9da536c797865f23e32edf77.jpg20220601_193241.jpg.1614a4e3938428eacd53647e15c31289.jpg20220601_193308.jpg.1ee158f1102dabf0bf9a1d18c2cc0ac2.jpg20220601_193316.jpg.d066a962d44e785ca3fda9185f534da5.jpg20220601_193421.jpg.8f4a43a158063e627dc79cfbb7900fc0.jpg
These are the old rods I pulled from mine. Doesnt appear to have the mushrooming..
On some of larger cummins, says rods could crack and fill with oil. Didnt hear a response if anyones come accross that in the 5.9s..
my guess is this truck used to have a high rpm life and the PO didn't replace the pushrods with HD ones.  I think prolonged high rpms beat them up good.
I think that is a good synopsis...
@SVALIN yup those look like mine just with out mushrooming lol.
I'm getting new rockers and push rods coming today.
Iffy on the bridges but I think they'll be ok maybe...
What's yalls thoughts on those?
Edited by Stanley
So the galling on the trunnions is not a fatal issue, an issue that plagues all of the cummins for sure, but not fatal.. When i brought the parts to one of the model shop guys at my previous job essentially the cast iron was being cold welded to the hardened trunnions. The damage was more on the rocker itself vs the trunnion.
Id wager factory pushrods as well.. orange band was the giveaway..
