- Replies 18
- Views 2.3k
SVALIN 7 posts
Mopar1973Man 5 posts
Me78569 2 posts
Threadzy 2 posts
Popular Days
I just had a good conversation with @Hutch24v just a bit ago. He's looking to squeak out just a bit more MPGs out of his truck. Again he's another person with improper ratios and EGT's are higher and
tone it down to like 110 at 0 psi then work up by 1% until 4 psi then go by 2% then bump that up to %5 at 10-15 psi. throw as much fuel at WOT as you can at it without smoke then use your right foot
I know this a common issues for guys adding wheels and oversized tires but to show a quick clip of running down the pavement semi-flat ground at 66 MPH and the tach shows a prefect 2,000 RPM's. The EGT floats today about 600*F, and boost is about 3-5 PSI. Had to try mounting to the side window and see if the GoPro could do it. I found out the LED lighting screws with the frame rate with the flashing displays which its not actually doing.
