- Replies 18
- Views 1.8k
Mopar1973Man 4 posts
Tractorman 4 posts
wil440 4 posts
IBMobile 2 posts
Popular Days
I digress temporarily from tire size. Choogle definition, (slang) To ball and have a good time. To ball, (slang) To engage in sexual intercourse. The use of the word ball was use
Yeah using general speak being out here it all 32 to 37 inch tires on 3,55 gears and wondering why there truck has excessive EGT's and low MPG's. More common issue that most think here. Now there is m
Non standard tire that will most likely be difficult to get. Here is the math on the 235/75 R16 tires.
So I have been kicking tires lol, this is what I came up with. My truck has to have 3.55 gear ratio, at 65 its 1800 or so and sucks as a 1 ton tow rig. This tire comparison is a Firestone LT 235 85 r16 to LT235 75 r16
Tire 1 Tire 2 Diff
Diameter 31.73 29,88 -6.19
with 9.25 same
sidewall 7.86 6.94 -13.33
circumference 99.68 93.86 - 6.19
Revs/mile 635.65 675.02 - 6.19
Speed 10 vs 9.38
20 18.76
30 28.14
40 37.52
50 46.90
70 65.66
This is some big diff. Im just not smart enough or able to search to find out if just changing tire size if I can achieve a 3.75 gear change just by down size my tires. Im sure someone has figured this out before.
Or am I stuck with changing rear end gears?
